USG60W - WAN1/2 link speed
ChrisGer
ChrisGer Posts: 206 image  Ally Member
Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
edited April 2021 in Security
Hi Zyxel community,
is there a official document, about the link speed for WAN1/WAN2 at a USG60W ?
i've connected the USG60W directly to my INAC (InterNet Access Connect) Firewall with Intel GBit Ports, but USG show only 100 Mbit ? is 100 Mbit correct by ZyXEL ?
Thanks an Regards
Christian
  • Zyxel_Emily
    Hi @ChristianG,
    Go to CONFIGURATION > Network > Interface > Port > Port Configuration and select 1000Mbps-Full Duplex on this port.
    Connect wan1 directly to INAC Firewall again and check if the status of P1 is 1000M/Full.
  • ChrisGer
    Hi @Zyxel_Emily
    thanks for your quick response. The Option Port is not visible on a USG60W [v4.32-WK52) ?
    is this onyl visible in a newer firmware version for USG60W ?
    Regards
    Christian
  • Zyxel_Emily
    Hi @ChristianG,
    Yes. It is new GUI enhancement in firmware 4.35.
    You can find this enhancement on page 22 of the release note.
