Console port
Hi @dpipro
Did you meet any question for NWA5123 series?
For the console, you can buy it from amazon.
Zyxel’s console header pin define: pin1 NA, pin2 White(RX),pin3 Green(TX), pin4 Black(GND), PS: Don’t connect red color pin to zyxel’s console pin.
You can buy any USB-to-Serial Bridge TTL 3.3V for Zyxel’s console port, and reference header pin define to connect.
Hope it helps.
Joslyn
Whats the PIN out plan for the devices? Is it all the same?
Hi @Pook,
Yes, the PIN out plan is the same for Zyxel WLAN enterprise devices which use 4 pin console cables.
Is there any problem when you use the cable?
As previous post mentioned, please note that DO NOT connect red color pin to zyxel’s console pin. The pin 1 is NA, and please align it with the triangle mark of the AP console.Zyxel Nebula Support
- 588 USG FLEX H Series
- 477 News and Release
ZCNE Certified
