Vlan tagging on Wan interface
Alfonso
Alfonso Posts: 257 image  Master Member
edited April 2021 in Nebula
Hi
I am testing a Nebula device.
I was not able to configure a vlan tagging on wan interface. So the device is not able to reach the nebula center.
I did not find any CLI document for NSG devices.
I am able to connect to the device via console port, so i think i will able to configure the vlan tagging on wan interface if a cli reference guide will be delivered.
Regards
  • Zyxel_Jason
    Zyxel_Jason Posts: 429 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @Alfonso,
    Currently, NSG only support VLAN tagging on LAN interface, not on WAN interface.
    I will move this topic to Idea section.
    Thanks.
    Jason
  • Zyxel_Jason
    Hi @Alfonso,
    Good news!
    After checking, we already have that feature in our future road map.
    Thanks.
    Jason
  • Alfonso
    Great news, thanks @Nebula_Jason
  • Alfonso
    HI @Nebula_Jason
    Do you know when this feature will be delivered?
  • Zyxel_Jason
    Hi @Alfonso ,
    The schedule of the feature will be in the first half of 2020.
    Hope it helps.
    Jason
  • Alfonso
    Hi @Nebula_Jason
    Do you have a more specific ETA?
  • Zyxel_Jason
    Hi @Alfonso ,
    The current schedule for this feature "VLAN tagging for WAN Interface" is around middle of January, 2020.?
    Thanks.
    Jason
  • Alfonso
    edited November 2019
    Thanks @Nebula_Jason
    I will ask again around middle of January :)
  • Nebula_Bayardo
    Nebula_Bayardo Posts: 179 image  Zyxel Employee
    Hey @Alfonso
    I guess you already know but just to make it official here ?. The VLAN tag on WAN has been supported in the last firmware available by the middle of January.
    Similarly to setting up the WAN IP address, this is available in the device local GUI only as normally this setting will be applied when the device is getting installed.
    Hope you are already making use of it ?
Nebula Tips & Tricks
