Is there really a limit of 20 Static IPs???
itxnc
itxnc Posts: 102 image  Ally Member
First Comment Friend Collector Seventh Anniversary
edited April 2021 in Nebula
I'm starting to have serious misgivings about buying these NSG50 gateways instead of USG40s. First I discover you can't apply different Content Filter/App Patrol profiles to different networks.
Now I'm trying to setup a network with a number of existing static IP devices and I get an error saying the limit is 20 items? Seriously??? Is there no way to configure more than that? Why such an arbitrary limit?
And why is the default font/view such you can't see the whole IP and MAC in the form? Its so tedious having to select and shift to make sure the data was entered correctly. If I zoom the page in a lot I manage to get MOST of it visible, but the last octet of the MAC never is.
  • CrazyTacos
    CrazyTacos Posts: 53 image  Ally Member
    First Answer First Comment Friend Collector Sixth Anniversary
    It's annoying but if you can connect your hosts under different VLAN interfaces, then that should allow you to set more static host addresses.
    And I totally agree with the ip/mac field being too small... There is definitely room for improvement.
  • Nebula_Bayardo
    Nebula_Bayardo Posts: 179 image  Zyxel Employee
    Hi @itxnc and @CrazyTacos
    The entries for DHCP static entries have been expanded. Now it will follow according what the NSG mode supports:
    NSG50:64
    NSG100:96
    NSG200:256
    NSG300:300
    Hope this helps you ?
Nebula Tips & Tricks
