ALG Configuration to NCC
did you type the "write" command to save configurations?0
Hello @ZeRicardo
Way ahead of you! I created a feature request for "SIP ALG on Nebula CC" shortly after closing your ticket.
But just to be clear, power failures or manually rebooting the NSG via Nebula CC will NOT cause the ALG configurations to disappear from the running configurations.
We are aware of only two reasons this configuration will disappear:
- Holding down the physical reset button to return to factory default settings.
- Removing/Transferring the NSG from one Organization to another.
Regards,
Barney Gregorio
Hi @ZeRicardo
SIP ALG is currently support from the last firmware and NCC upgrade in January ?
- 221 Nebula Ideas
- 614 USG FLEX H Series
- 53 Wireless Ideas
- 483 News and Release
