[NEBULA] NSW's Default managment IP
WaYne
WaYne Posts: 12  Freshman Member
First Answer First Comment Friend Collector First Anniversary
edited April 2021 in Nebula
Hi all,
Does anyone know what is the default IP of NSW? I was trying of configuring my IP to a static one before connecting it to the internet but I gave up. It confuses me because typically it should be 192.168.1.1 but this one is not working.
any ideas?
Wayne
  • BackZero
    BackZero Posts: 17  Freshman Member
    Hi WaYne
    I think there is no default static IP since NSW is DHCP client by default. Probably you need to connect the device to Internet to get the DHCP IP first. You can refer to more info in NSW series user manual page 25
  • Iwannaquitthegym
    Iwannaquitthegym Posts: 23  Freshman Member
    edited May 2017
    Isn't NAP DCHP client by default as well? and still has an alternative IP address...
    How will you connect to internet if you don't have an IP? :trollface:
    @WaYne as far as I know, the NSW doesn't have a default IP address, dunno why tho....
  • Zyxel_CSO
    Zyxel_CSO Posts: 458  Zyxel Employee
    5 Answers First Comment Friend Collector Eighth Anniversary
    edited May 2017
    Hi All
    NSW has no default IP at the moment. In order to address the inconvenience, we will enhance the function with the default IP in the coming future. Please stay tuned for more details.
    Zyxel Nebula Support
  • Zyxel_Albert
    Zyxel_Albert Posts: 36  Zyxel Employee
    First Answer First Comment Friend Collector Third Anniversary
    Hi all.
    To solve this problem I recommend you a zyxel convenience tool, ZON utility. ZON can help you easily setup a static IP. You can download it on ZyXEL official website. https://www.zyxel.com/tw/zh/products_services/zon_utility.shtml?t=p
Nebula Tips & Tricks
