[NEBULA] WAN2 as backup line for WAN1 on NSG100
Hi
I have done several tests regarding WAN2 as backup for WAN1. What is the result is that it takes between 20 and 30 minutes for VPN to come up again after I either close for the internet or take out the plug in WAN1. It is also the same result whether I use a fixed internet line or whether I use LTE/4G as backup line.
I think it takes too long for VPN to come up again in terms of it taking less than 1 second for the internet to be available again.
Do you have a solution or explanation to the problem?
H
Olav
Hello @Elgen007
I can found the similar symptom in my local site we are working on it, will update to you once get further steps, sorry for any inconvenience.
/Chris
Hi @Elgen007 ,
Just an update.
We are doing some more tests about the scenario you mentioned, so still need some time to tune the behavior as what we expect.
We will keep posting here when we have further update.
Hope you understand.
Hi
Is there anything new regarding this matter?
h
Olav
Hi @Elgen007
Apologize for the late reply, in the current stage we have optimize the recover time to 5~10 minutes and we know there is still has the space to get it better in future.?
Hi
That's good, thanks?️?.
Olav
- 588 USG FLEX H Series
- 477 News and Release
