[NEBULA] NAP102 AP couldn't change SSID from Nebula Cloud Configure
Sammy
Sammy Posts: 1 image  Freshman Member
edited April 2021 in Nebula
I have tried many times to change my SSID from your Nebula cloud platform. I have been getting the same error message. Please see the attached screenshot.
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360
    25 Answers First Comment Friend Collector Fourth Anniversary
    image  Zyxel Employee
    Hi @Sammy
    It seems there might be something wrong in the configuration. Could you provide your org/site name for us? Please also help to enable the ZYXEL support privilege. We will check the configuration and find out the root cause.
    Joslyn
  • Zyxel_Joslyn
    Hi @Sammy
    The issue was fixed. Could you help to try it again?
    Please let us know if you have any question.
    Thanks.
    Joslyn
Nebula Tips & Tricks
