[NEBULA] NSG scheduling rule not working
Hughie
Hughie Posts: 36 image  Freshman Member
First Comment Friend Collector Sixth Anniversary Nebula Gratitude
edited April 2021 in Nebula
Hi there
I have setup a rule (rule 4 in this case)
Policy - Allow
Protocol - Any
Source - Single address /32
Destination - Any
Dst Port - Any
Schedule - Name of schedule
The schedule is set to allow access from 16:00 until 21:00. This is the green bar, and availability set to on.
So i would assume that the green bar / schedule is when the rule is active? As the next rule ( rule 5) below the above rule is a deny rule for that single source.
What i am seeing in the logs is that at 16:30 for example that i am still denied (Priority 4 - which i assume is rule 4) which is the scheduled rule not the denied rule.
Looking for some guidance on the scheduling.
  • Zyxel_Jason
    Zyxel_Jason Posts: 430 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @Hughie ,
    I try to reproduce the issue, but I don't see the same symptom.
    Here is my configuration for you to refer: (192.168.3.38 is my PC)
    Policy Protocol Source Destination Dst port Schedule
    Allow Any 192.168.3.38/32 any any NewSchedule
    Deny Any 192.168.3.38/32 any any Always
    The profile of NewSchedule:
    Result: My PC can't ping 8.8.8.8 until 11:30.
    If your configuration is correct on NCC but you still encounter the issue, please enable Zyxel Support(Help>Support request) and provide us your organization/site. We may help to check your configuration on your NSG.
    Thanks.
    Jason
Nebula Tips & Tricks
