[NEBULA] What does Asterisk mean?
Hi @KYH
An asterisk(*) displays on Channel means the primary channel on the NAP. Take an example as the below. If Channel shows "11 [2.4GHz] 40*/36/44/48 [5GHz]", it means Channel 40 is the primary channel for 5GHz on this NAP.
Zyxel Nebula Support
Could I manually change other channel as my priority one?0
Hi @KYH
Yes, you can specify the other channel as your primary one. Take the above as an example, the primary channel was 40 on 5 GHz. You can change the primary channel to the other such as 36 as below:
Go to NCC > Configure > Radio setting. On the button page, select Edit on the Access point, you can lock up the channel as the major one.
- 588 USG FLEX H Series
- 476 News and Release
