[NEBULA] how do i disable two factor authentication?
I've enabled 2fa on NCC. At the time I don't recall setting anything up on my mobile, if I did it's now lost the settings so I can't get a code. I've managed to get into NCC by telling it I've forgotten my password but once in there I can't disable 2fa without having the 2fa code... a deadly embrace.
Seems i have two issues, the initial setting didn't seem to have persisted properly - I'm wondering if it was ever set-up correctly... but now I'm locked out how do I remove 2fa?
thanks
Ian
thanks
Ian
Hi @lanUK,
In the current situation, I'll PM you to retrieved more detailed information.
Please check your personal message.
Thanks.
JonasJonas,5
Hi @lanUK,
Thanks.
JonasJonas,5
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
