Nebula 2.0 not working in Edge
Hughie
Hughie Posts: 36
First Comment Friend Collector Sixth Anniversary Nebula Gratitude
image  Freshman Member
edited April 2021 in Nebula
I have moved across from Nebula 1.0 to 2.0 in Microsoft edge and although the dashboard loads I can not get into any of the devices menu's
Swap back is fine / Cleared cache - refreshed etc does not work.
Have had to move to chrome!!
  • RUnglaube
    RUnglaube Posts: 135
    5 Answers First Comment Friend Collector Third Anniversary
    image  Ally Member
    edited April 2020
    Update it to the latest Microsoft Edge Chromium. It works just fine for me. I'm starting to prefer Edge over Chrome now
    "You will never walk along"
  • TomorrowOcean
    TomorrowOcean Posts: 60
    First Comment First Answer Friend Collector Seventh Anniversary
    image  Ally Member
    I use new Microsoft Edge on Nebula 2.0 with no issue.
  • Alcindo
    Alcindo Posts: 4
    First Comment Sixth Anniversary
    I can confirm updating to the Chromium Edge version resolved the vertical menu bar issue.
    Alcindo
  • Hughie
    Hughie Posts: 36
    Have upgraded to Chromium and it is now working. The problem with Edge was replicated on two different PC's. The vertical menu did not appear.
Nebula Tips & Tricks
