Nebula 2.0 not working in Edge
I have moved across from Nebula 1.0 to 2.0 in Microsoft edge and although the dashboard loads I can not get into any of the devices menu's
Swap back is fine / Cleared cache - refreshed etc does not work.
Have had to move to chrome!!
Update it to the latest Microsoft Edge Chromium. It works just fine for me. I'm starting to prefer Edge over Chrome now"You will never walk along"0
+1
I use new Microsoft Edge on Nebula 2.0 with no issue.0 -
I can confirm updating to the Chromium Edge version resolved the vertical menu bar issue.
Alcindo0 -
Have upgraded to Chromium and it is now working. The problem with Edge was replicated on two different PC's. The vertical menu did not appear.0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
