[NEBULA] InterVLAN routing
MartyWalter
MartyWalter Posts: 32 image  Freshman Member
First Comment Sixth Anniversary
edited April 2021 in Nebula
I need to route between Lan1 and Vlan7.
Lan1 Gateway 10.77.98.148
Lan1: 10.77.98.0/24
VLAN7 Gateway: 172.16.0.1
VLAN 7: 172.16.0.0/24
I have tried to set up a static route:
Type: Intranet
Protocol: Any
Source IP: 10.77.98.0/24
Source Port: Any
Destination IP: 172.16.0.0/24
Destination Port: Any
Next Hop: 10.77.98.148
I am able to ping IP addresses between networks, just not able to route data (i.e. web traffic between computers and PBX)
  • [Deleted User]
    [Deleted User] Posts: 0 image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    May I know if these 2 IPs are in the NSG or not, can you share your topology for me (you can post here or PM me)
    Is your issue that phone cannot register to the server, I assume that your phone and server are in these LANs (LAN1 and VLAN7)?
  • [Deleted User]
    I will PM you about the organization access privilege, please be aware the Inbox message.
  • Pook
    Pook Posts: 153 image  Master Member
    First Comment First Answer Friend Collector Nebula Gratitude
    What was the fix?
  • [Deleted User]
    Because I didn't receive the response from this user therefore the root cause is unclear.
Nebula Tips & Tricks
