[NEBULA] export the cvs file of Cloud Authentication with a line command
Mvellar
Mvellar Posts: 2
image  Freshman Member
edited April 2021 in Nebula
I need to export the cvs file of Cloud Authentication with a line command, I already use a macro with imacro for chrome, but i need to automatizate the process with a dos script or with some utility. There is a way?
  • TomorrowOcean
    TomorrowOcean Posts: 60
    First Comment First Answer Friend Collector Seventh Anniversary
    image  Ally Member
    Why do you need to use macro/script to export cloud authentication?
    There should already have import/export feature in that page on NCC.
    Or, you have many organizations?
    If I misunderstand what you mean, maybe you may share your motivation to have a script.
  • Mvellar
    Mvellar Posts: 2
    The mails that are in the cloud authentication are used for a mailing list, I would like to automatically synchronize the contacts, as every day there are new mails in the cloud authentication (it is a restaurant / bar), I am creating a program that updates the mail database of the utility that generates the newsletter.
  • Zyxel_Jason
    Zyxel_Jason Posts: 432
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    image  Zyxel Employee
    Hi @Mvellar
    Welcome to Zyxel Community!
    We are already evaluating a feature and put it in our feature road map to fulfill this kind of scenario you mentioned.(Captive portal with self-registration)
    I will move this post to idea section and monitor the Likes and comments.
    Thanks.
    Jason
Nebula Tips & Tricks
