[NEBULA] Guest network not internet
Best Answers
Hi @boblWhen you enable the guest network, the Layer 2 isolation will be enabled and the gateway on AP will be added to the white list automatically, so if the DNS or DHCP server is different device from the gateway and in the LAN, please add the MAC addresses to Access point> Configure> Authentication> Layer 2 isolation.If you still have any problem after checking the Layer 2 isolation, please help to enable Zyxel support privilege at HELP> Support request, and share Org/site , network topology information as well.
We'll check the relevant settings on it.Thanks!
Best Regards,
Panda5 -
Thanks Panda. I will look into it.0
Best Regards,
Panda5 -
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 484 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
