[Nebula] Block device
Hi @paulb,
Yes, there is method on both devices.Reminder: Click the "Save" button after the modification.
Switch: create an ACL deny rule to block the specific device/user.
Located at Switch > Configure > ACL
NSG: create firewall rule to block the specific device/user.
Located at Security gateway > Configure > Firewall
Hope it helps.
Jonas,Jonas,2 -
Hi
I suppose the first method is the only effective way to do it.
The second one could be allowing the flows with other devices in the same vlan (unless the device would be connected directly to the NSG).
Also some specifics attack (as layer two attacks) could be done (DHCP poison, ARP poison ...).
So I always recommend block the device directly in the switch.
Regards0
- 234 Nebula Ideas
- 6.7K Security
- 719 USG FLEX H Series
- 371 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 315 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
