Nebula Information
Falrath41
Falrath41 Posts: 4 image  Freshman Member
First Comment Nebula Gratitude Fourth Anniversary
edited April 2021 in Nebula
I have an NSG100 and 11 NSG50s. When I log into the website (doesn't matter which browser) I can view some information, but for the last month or so my Security Gateway-->Monitor--> Clients NEVER loads. I cannot see the clients connected as I used to be able to see.
I have cleared all cookies, cache, everything. I even installed a new browser I have never used on my computer and still is just tried to load the USAGE for the last 2 hours and never gets past that.
Is anyone else having this issue? Is there something MORE I needed to do for this to work? I normally use Google Chrome, but I have the same issue with Edge and Firefox.
  • Zyxel_Jason
    Zyxel_Jason Posts: 430 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @Falrath41 ,
    Does the issue happen if you use another PC?
    If the issue only happen to the specific PC, please help to check the time on the PC.
    We have another user encountered the same symptom that the client page couldn't display correctly, but it works well with same account on other PCs.
    We finally found that the time of PC was wrong, after correcting the time, everything back to normal.
    Hope it helps.
    Jason
Nebula Tips & Tricks
