NSG - Muptiple WAN and LAN IP addresses - Feature request
forss
forss Posts: 3 image  Freshman Member
First Comment Sixth Anniversary
edited April 2021 in Nebula
We've got a case where the customer have 3 IP-addresses from their ISP.
They would like to use one as primary address and the other two as 1:1 NAT addresses.
But it's not possible to configure multiple WAN1 IP addresses in Nebula.
We've also got customers with multiple IP subnets within the same VLAN (default VLAN).
For example: 192.168.0.0/24 and 192.168.40.0/24
In the USG series firewall we could add more IP addresses to the LAN1 interface (without having more VLAN:s).
But here it's not possible to have both 192.168.0.1 and 192.168.40.1 as IP addresses of the LAN1 interface.
  • miestermann
    miestermann Posts: 2 image  Freshman Member
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
    forss,
    Not sure about adding multiple IPs on the same LAN1 interface with USG series firewall. That doesn't sound like a good idea though. Best practice is to place each subnet on a different VLAN. Whats the use case?
    I second the need for more control over WAN addressing.
Nebula Tips & Tricks
