IPsec VPN problem
IT_Field_Support
IT_Field_Support Posts: 97  Ally Member
edited April 2021 in Security
Hi guys,
Just a quick question. We have one VPN gateway used by 2 phases 2 on a USG40W as we have on many other router without any problem.
On this one, for an unknown reason, phase 2 are never connected both at the same time, there are dropping all the time, sometime we can ping through these phase 2 but it is very unstable.
I tried with firewall off and it's still the same.
In the debbug logs, I notice some weird error regarding IPSec, why would IPSec drop packet ?
Thanks for help,
Davy
IPSec Dropping packet. ret=1, step=11
IPSecSPI: 0x0 (0) SEQ: 0x0 (0) No rule found, Dropping TCP packet. ret=1, step=11
IPSec SPI: 0x0 (0) SEQ: 0x0 (0) No rule found, Dropping UDP packet. ret=1, step=11
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,431  Zyxel Employee
    @IT_Field_Support,
    I've applied your configuration file to USG40W to run the test.
    The test result is sent to you in the private message.
  • Irfan
    Irfan Posts: 3  Freshman Member
    Hello ,
    On zyxel wal usg50 getting this erro
    any help?
  • Zyxel_Emily
    Hi @Irfan,
    What is the model of the remote site of VPN tunnel?
    Could you share startup-config.conf of USG50 and topology with me in private message?
  • Irfan
    Ok thanks , now i upgrade USG50 with latest firmware which you sent me..
    Than let you know.
