Cannot get registered AP NWA 1123 online in nebula
RayCap
RayCap Posts: 1  Freshman Member
edited April 2021 in Nebula
I registered device, it says offline, steady green light
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @RayCap
    If the LED is steady green but not connecting to NCC, it means the AP configuration is not default. Could you try to reset the AP back to default and connect it back to your environment? Ensure it can surf the internet, then it sould connect to NCC automatically.
    Please let me know if it helps.
    Joslyn
Nebula Tips & Tricks
