L2TP/iPsec Windows
Pook
Pook Posts: 145  Ally Member
First Comment First Answer Friend Collector Nebula Gratitude
edited April 2021 in Nebula
Hey guys
I don't have any issues setting up in Nebula or getting the clients connected. But once connected it all goes wrong, on every machine I have had to add a route add command so the machines can see the remote network such as below...
route add 192.168.1.0 mask 255.255.255.0 172.16.0.0
I have added batch files in machines startup folders but this isn't a great long term solution, any ideas what I need to do or is this the norm using Windows VPN client?
  • Zyxel_Chris
    Zyxel_Chris Posts: 728  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    Can you be ensure if those L2TP profiles has enable the "Use default gateway on remote network" in advanced TCP/IP settings?
    If not then activate the support request also the org./site name for me to check.  =)
  • Pook
    Thanks Chris, I always leave this unchecked as from past experience it causes slow internet browsing but I will give it a try :-)
Nebula Tips & Tricks
