ZyWall 110 update from Firmware version v3.10 to 4.x
Hello there
We have a ZyWall 110 here, with firmware version V3.10(AAAA.2) on it..
1) Is it possible to update from v3.10 to v4.13? (that was the lowst version i found on the zyxel.com ftp srv)And after that i would update Version by Version as recommended or dons't that matter if version v4.13 or higher from v3.10
2) Is there a way to download the firmware version V3.10(AAAA.2)?
just in case something goes wrong with the firmware update and i have to go back to this version.
thanks in advance
Pat
The firmware has been private message to you. Please have a check.
Before upgrade the firmware, you need to backup the configuration first, and update by each version. Currently, the latest firmware is v4.60, but I suggest you should upgrade at least to v4.38.1
Pat
Before upgrade the firmware, you need to backup the configuration first, and update by each version. Currently, the latest firmware is v4.60, but I suggest you should upgrade at least to v4.38.1 -
- 3K Nebula
- 230 Nebula Ideas
- 6.6K Security
- 669 USG FLEX H Series
- 359 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 307 Service & License
- 500 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
