NWA1123-ACv2 Upgrade failed
I was trying to Update my NWA1123-ACv2 to an newer Version.
Currently i have an old Version on it (Blue UI).
If i'm trying to Upgrade it , it always stays on the same Firmware after a 3 min Timeout and no reboot.
I get no Error Message.
WebUI Upgrade nor FTP Upgrade Method seems to work.
Hi @C0nvert
For firmware upgrade, we suggest not to cross too many version. If you are using v4.26, just upgrade it to v5.00 then v5.10 because it will avoid some configuration parse error.
Can you let me know your original firmware version and will upgrade to firmware version?
Joslyn0 -
It doesn't mather if i use v5 Firmware or newer.
For a brief Moment i had the new Interface v5.10 but after a router restart it got back to v2
Thought it could be a Problem with the Browser Cache, so i deleted the Cache from Chrome and tried even a different Browser.
Same result. Only the old UI v2 is visible.
Edit i'll try something and will report later0 -
Did you get resolved? Maybe fully factory reset before trying?
- 588 USG FLEX H Series
- 477 News and Release
