Black listing wildcard issue on NSG50 V1.33 ABHP.4
thwartedEfforts
Among numerous domains in my NSG50 Black list at Security gateway > Configure > Security service I have the following wildcard entry:
The issue is that the wildcard does not seem to be behaving in the expecting manner. If I browse to:
https://yt3.ggpht.com/
then my browser displays a response from the web server in defiance of the above
However, if I update the NSG Black list to the FQDN:
I will correctly receive the Web access is restricted. Please contact the administrator denied access message from the NSG. I can replicate this with all the other domains in my list e.g. *.ytimg.com
It appears the wildcard is not working?
*.ggpht.com
yt3.ggpht.com
Hello @thwartedEffortsI can't reproduce this problem, can you activate the support request and provide your org./site name for me then I can check with your device configuration
Chris,
I've responded via the Nebula interface using the Ask Question pop-up in the bottom right corner. However, I've just discovered the separate Support request page which allows me to invite Zyxel support as administrator so I'm about to fill that out too.
Not sure if you are able to close the duplicate Ask Question request.
UPDATE case no. #2012002180
- 588 USG FLEX H Series
- 477 News and Release
