Load balancing tag
Yes, the load balancing tag works if one of AP reach to the threshold.
There are 2 places where you can modify the tag, one is click the pencil icon and the other is in the access point list page.
Sorry, my bad.
You can use Load balancing tag to put many APs in the same group, for instance there are four APs, AP1 and AP2 with same tag, AP3 and AP4 (with same tag) then one of AP exceed the maximum client number and other client can only connect to the AP which has the same tag name.
Chrystal clear! thanks @Nebula_Chris
it will only kick in once the load balancing limit set in the AP & port settings has been reached.
for example, if I set the limit to 100 devices, the load balancing tag will only work if one of the APs reaches 100 devices
Correct, since there are 2 mode and for more detail information please refer to our user guide page 247.
- 237 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
