Load balancing tag
Carlo
Carlo Posts: 48 image  Freshman Member
edited April 2021 in Nebula
I noticed the load balancing tag option in the detail page of the WAP.
how can this option be utilised?
does it have anything to do with the load balancing in the AP & port settings page?
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Guru Member
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    There are 2 places where you can modify the tag, one is click the pencil icon and the other is in the access point list page.
  • Carlo
    Hi @Nebula_Chris
    I'm referring to the load balancing tag, not the WAP tag.
  • Zyxel_Chris
    Sorry, my bad. :s
    You can use Load balancing tag to put many APs in the same group, for instance there are four APs, AP1 and AP2 with same tag, AP3 and AP4 (with same tag) then one of AP exceed the maximum client number and other client can only connect to the AP which has the same tag name.
  • Carlo
    Chrystal clear! thanks @Nebula_Chris
    it will only kick in once the load balancing limit set in the AP & port settings has been reached.
    for example, if I set the limit to 100 devices, the load balancing tag will only work if one of the APs reaches 100 devices
  • Zyxel_Chris
    Yes, the load balancing tag works if one of AP reach to the threshold. :)
  • Zyxel_Chris
    Correct, since there are 2 mode and for more detail information please refer to our user guide page 247. :)
Nebula Tips & Tricks
