ZyWall USG2000 FW 3.30(AQW.7)C0 gets "Unable to connect ZySH daemon", WebGUI won't work
hansjalbertsson
hansjalbertsson Posts: 34
edited April 2021 in Security
ZyWall USG2000 FW 3.30(AQW.7)C0 gets "Unable to connect ZySH daemon" when in ssh as admin, WebGUI won't work.
What do I do to get it working, and what could be the reason??
«1
  • Blabababa
    Blabababa Posts: 151
    5 Answers First Comment Friend Collector Fifth Anniversary
    Is it all the time showing "Unable to connect ZySH daemon" or just in short period? If it just showed in short period, could be the system just busy on handling something else for minutes.
  • hansjalbertsson
    Mark said:
    Dear @hansjalbertsson
    I would suggest you flash the usg with the latest Weekly firmware available:
    ftp://cpeguest02:[email protected]/USG_3.00_weekly_date_code/V330_based_2016/2016-WK48/USG2000/330AQW7ITS-WK48-r74988.zip
    Basicly FTP upgrade would be advisable.
    So connect a pc in your local lan wired to the usg
    start a command prompt with admin rights
    then type ftp [zywalls ip address] and login with admin and password
    Then if successful , set the mode to BINIARY with the command : bin
    after that give the command put c:\firmware.bin [location where firmware is downloaded]
    Hit enter and it will start the firmware upgrade..
    Let me now if you have any questions !
    Kind regards
    Mark
    This is close, there's actually a document from zyxel that addresses this. This will be part of the fix.
  • hansjalbertsson
    It's a permanent state.
  • hansjalbertsson
    Kind regards
    Mark
    I guess I should say
    ftp> put 330AQW7ITS-WK48-r74988.bin  /Firmware
    because I think the usg looks for the bootable FW in /Firmware, doesn't it?
    Ftp from windows doesn't work!!!??? Any ftp from any of my Unix machines seems to work OK.
  • [Deleted User]
    [Deleted User] Posts: 118
    No this is not needed If above does not work for you it seems more alike a local issue on your pc.. (firewall, anti virus,software) what is causing an error...  you can also use on your  windows client  a software tool like FILEZilla.. there  you just connect again with the usg en drag en drop the bin file directly in the root .. This is also applicable to almost all our modern firewalls, Acces points, wireless controllers and home routers/modems
  • hansjalbertsson
    Why is then the old firmware in there named /Firmware??
  • hansjalbertsson
    Re ftp not working: FileZilla works very well.
    PROBABLY I have some issue with my W10 firewalls, I am NOT a Windows person.
  • [Deleted User]
    i guess you are pointing to the standby firmware? but then again i am 100 % sure what is said.. I do like daily upgrading cases with ftp. you can also check our one security site:
    http://onesecurity.zyxel.com/tutorials
    then under [Firmware Upgrade Procedure] you can find a document where you can see the same
  • hansjalbertsson
    And this is true even in a USG2000 ???
Security Highlight
