USG310 DNS over VPN
Hi @weite
4.60P1 has fixed issue which USG unable to initial DNS query via VPN tunnel.
You may upgrade firmware to 4.60P1 first.
Or you can add Static Route on your USG310.
e.g. if your local LAN IP address is 192.168.1.1 and peer IP subnet is 192.168.10.0/24.
Then you can add static route like it:
Then USG initial traffic to 192.168.10.0/24 will pass into VPN tunnel which you established.
Hi @weite
Thanks for the fast answer. I installed the 4.60P1 and all is well. It can be so easy.
Many Thanks!!!
- 588 USG FLEX H Series
- 477 News and Release
