How to check 2nd Multy performance after initial set up?
Cookiemomo
Is there a method to check my 2nd Multy performance after initial set up? I've moved my 2nd node several times, and not sure how well the performance is. (ex: distance & signal strength)
@Cookiemomo,
A speedtest can show the actual performance instead of signal. On the bottom menu in current APP landing page, the second icon is for Diagnose, you can click "Start" to activate an immediate speedtest, 1st will test RootAP to Internet, 2nd will test ExtAP to Internet, 3rd will test ExtAP to RootAP. Notice..... you may miss to see the 3rd test due to the 3rd result will show out of the screen. Just touch the up-arrow icon in the middle of this page, the full 3 items will be scrolled up and you'll see.2
@Cookiemomo,
You can find following results when run diagnose function.- 1st node to internet
- 2nd node to internet
- 1st node to 2nd node
@Cookiemomo,
A speedtest can show the actual performance instead of signal. On the bottom menu in current APP landing page, the second icon is for Diagnose, you can click "Start" to activate an immediate speedtest, 1st will test RootAP to Internet, 2nd will test ExtAP to Internet, 3rd will test ExtAP to RootAP. Notice..... you may miss to see the 3rd test due to the 3rd result will show out of the screen. Just touch the up-arrow icon in the middle of this page, the full 3 items will be scrolled up and you'll see.2 -
I would just stand right by the device and try fast.com. Seems way easier0
@Gaby Yes, that would be another option. Just wanted to note, I personally don't recommend fast.com as they may not have enough servers or bandwidth that can test the full speed of the Internet to a user's home. I strongly recommend using SpeedTest.net, this way it ensures it's testing the maximum Internet speed with a server that's closer to the user's home. See example below:
- 441 Beta Program
- 209 Nebula Ideas
- 534 USG FLEX H Series
- 337 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
