only 100 mbps wireless extender?
Old_Pop
Posts: 4 Freshman Member
is your wre6505v2 limited to 100 mbps? newegg listed "00 mbps" for 2.4 Ghz
Hey @Old_Pop, yes, if you're connecting that way - you will be limited to 100 Mbps from the fast Ethernet port. When you're setting it up, please ensure that you're using "AP mode". If you need a faster connection under AP mode, we recommend a WRE6606 or an ARMOR X1 access point - these two products provide gigabit Ethernet connection (up to 1,000 Mbps for Ethernet).2
@Old_Pop
It should be 300Mbps for WRE6505v2.
If you need more specification information for WRE6505v2, please check the datasheet.
You can download it from the following link:
WRE6505v2 Datasheet
i'm sorry i'm a little confused. it says "10/100 Mbps Ethernet port". i want to cconnect this behind an old router i have with a long Ethernet cable, does that mean i will only be able to connect at 100 mbps? thank you0
@Old_Pop
If you connect WRE6505v2 with an Ethernet cable to your router, all clients connect to WRE6505v2 will get maximum 100Mpbs when surfing the Internet because the speed is limited by the Ethernet port.
thank you @Zyxel_Bear0
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 91 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 919 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 926 Nebula FAQ
- 422 Security FAQ
- 238 Switch FAQ
- 210 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
