How do I pause network access on certain devices?
Cookiemomo
I would like to know if I can pause/block my internet on certain devices during the day while I'm out of the house.
#MultyX_September
#MultyX_September
There are two way to block the device to access Internet.1. Please go to "Parental Control" page and tap the device. Disable "Connect to the Internet".
2. Setup the block schedule for a group.
You can refer to the link of FAQ: How to set up the Parental Control feature?
And Multy X app supported remote control your home network.- Make sure your home network is running.- Your mobile device is able to access Internet.0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
