factory password
Me36
i just got the zyxel EMG2926-q10a, i cannot log into it hardlined in to my computer with the 192.168.1.1 it times out. i cannot sign into it wirelessly either bc the factory password on the back is 4 digit and it dosent even give you the connect option until 8 characters have been entered. ANY CLUE???
#CPE_September
#CPE_September
Did you check your PC get IP from EMG2926-Q10A? Since EMG2926-Q10A support auto-ip change that EMG detect same subnet with root AP, it will change IP to 10.0.0.1. That might the reason you cannot ping 192.168.1.1.1
@Me36 Thanks for you choose Zyxel model. As your question, I would like to suggest you find ISP or local support for helping. Since different ISP might use different lan IP/PW...etc customize setting. You might get those information from your ISP, thanks.0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
