[100201]Is there any VLAN Tag on the ethernet Ports on the Multy X?
with a router provided by the isp it works with a router from AVM Fritzbox is not working the IPTV0
Please provide more information to clarify this problem.IPTV works:1. Which ISP?2. Typologies
3. If you're using the router by yourself to replace the router by ISP, is Multimedia Receiver working?IPTV not works:1. Which ISP?2. Typologies3. With a router from AVM Fritzbox is not working the IPTV.-> What's model name?-> Does it provided by ISP?-> Without Multy X, Multimedia Receiver is working when it connected to router's LAN1,With Multy X, Multimedia Receiver is not working, does Multy X connected to router's LAN1?4. Could Multimedia Receiver worked when it connected to router's every LAN port? Or only works on specific port?0 -
Hi team,
i already shared my environment of testing.
The differences between my test and the other test was the Router in front.
ISP is the same it is Deutsche Telekom.
My router is a totally based Telekom Router with Telekom FIrmware on it.
The other router was a Fritzbox (AVM) 7490 with AVM Firmware on it.
These is the different......
My Labs are like this
The scenario at home was like this.
ISP <--> Speedport (from the Telekom) <--> Zyxel PLA5456 <--> Telekom Media Receiver 401 <--> TV
The IP Range was 192.168.40.1 (Speedport Router) 192.168.40.10 Telekom Media Receiver and it works
My Test Scenarios were like this:
Lab 1:
ISP <--> Speedport <--> Multy X <-->Telekom Media Receiver 401 <--> TV
IP Range was like this
192.168.40.1 for the Speedport
192.168.40.10 was the IP Adress on the WAN of the Multy X
192.168.212.40 was the ip adress of my pc
192.168.212.41 was the ip adress of the Media Receiver
Result: Stream was working. Also switching between the channels were ok.
Lab 2:
ISP <--> Speedport <--> Multy X <--> PLA <--> Media Receiver 401 <--> TV
Lab 3:
ISP <--> Speedport <--> Multy X 1st Node <--> Multy X 2nd Node <-->Media Receiver <--> TV
Thanks for the information. Please kindly help to confirm below questions:ISP <--> Fritzbox (AVM) 7490 <--> "Multy X" <--> Telekom Media Receiver 401 <--> TV- Do you try to use other brand's router to replace Multy X? (Such as Orbi ...) Does it works properly?- Do you configure particular setting on Fritzbox (AVM) 7490 for IPTV streaming? Is possible to let us know the setting?0
Hey Team,
sorry nobody has an Orbi so that we can test this.
The AVM Fritzbox works fine with the Multimedia Receiver without Multy X in between.
But do not get me wrong. A normal Consumer will not configure his Fritzbox for working Multy X and Multimedia.
It should be like a plug and play Systems0
- 441 Beta Program
- 529 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
