NSA326
RadaSed
Since the first attempt did not work, I restarted the NAS to the factory setting and started it again. I have installed the installation as described. Unfortunately, the last step - when I have to enroll \\ nsa326 to see shared drives ... and have access to it does not work. Do not you have a similar experience? Any tips and advice about what ???
#NAS_October
#NAS_October
@RadaSed,
Check Server Name and Workgroup Name of NAS326,
suggest setting Workgroup Name the some with domain name of your windows PC.
Control Panel > Server Name
Maybe following link is helpful.
https://technet.microsoft.com/en-us/library/cc940089.aspx
Can you test with :
\\NAS326
and not :
\\ nsa3261 -
Yes,I tested both options and the result is negative.
@RadaSed,
Thanks for the tip. I have this as well.
- 3K Nebula
- 229 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 661 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 305 Service & License
- 497 News and Release
- 95 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
