Frozen NAS
RadaSed
RadaSed Posts: 16  Freshman Member
Sixth Anniversary
edited November 2017 in Personal Cloud Storage
New NSA326. After a few days and I had to restart operations. However, since it is the only image and spinning around. Someone with similar experience?
#NAS_November
  • Ijnrsi
    Ijnrsi Posts: 254  Master Member
    You can clean browser's cookie and check the NAS326's IP address, maybe NAS326's IP address is chaneed, then you see the history page.
    If no different, then you can try to reset the device.
  • RadaSed
    Sixth Anniversary
    I already did ... the reset went off.
  • Fredzoul1
    Fredzoul1 Posts: 97  Ally Member
    If you use the NSU software from Zyxel, can you find with success your NAS326 ?
    Download link : ftp://ftp.zyxel.com/NAS326/software/
    If not, try the hard reset (3bip) and reconfigure all from start... But before this, Check your network (cable RJ45, switch, router).
  • RadaSed
    Sixth Anniversary
    Connection is OK. Copy files and move is already OK. Issue is on login to www administration.
  • Mijzelf
    Mijzelf Posts: 2,956  Guru Member
    Did you install FFP on that box? It's known to kill the webinterface on a 326. (And only on a 326)
  • RadaSed
    Sixth Anniversary
    I don't understand what you mean by FFP? Sorry for a question.
  • Fredzoul1
    @RadaSed,
    Are you solved your default ? Do you want more help ?
    Best Regards
  • RadaSed
    Sixth Anniversary
    Nas still not as I would wish, but I'm working on it. Thanks.
