Frozen NAS
RadaSed
New NSA326. After a few days and I had to restart operations. However, since it is the only image and spinning around. Someone with similar experience?
#NAS_November
You can clean browser's cookie and check the NAS326's IP address, maybe NAS326's IP address is chaneed, then you see the history page.
If no different, then you can try to reset the device.0 -
I already did ... the reset went off.
If you use the NSU software from Zyxel, can you find with success your NAS326 ?
Download link : ftp://ftp.zyxel.com/NAS326/software/
If not, try the hard reset (3bip) and reconfigure all from start... But before this, Check your network (cable RJ45, switch, router).0 -
Connection is OK. Copy files and move is already OK. Issue is on login to www administration.
Did you install FFP on that box? It's known to kill the webinterface on a 326. (And only on a 326)0
I don't understand what you mean by FFP? Sorry for a question.
Nas still not as I would wish, but I'm working on it. Thanks.
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 365 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 263 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
