Can this device expand the WiFi area between two different buildings?
Rani
Rani Posts: 3 image  Freshman Member
edited November 2017 in Multy WiFi System
I would like to get information about the multy x wifi system.Can this device expand the WiFi area between two different buildings?
#MultyX_November
  • Hanamichi
    Hanamichi Posts: 125 image  Ally Member
    You can check: Specifications
    A set of two Multy X units can cover up to 5,000 square feet.
    But it is wireless signal and interference from other networks/appliances/wall could be reduce the coverage. What is the distance between two buildings?
  • Rani
    About 30,000 meters between two buildings
  • Hanamichi
    Do you mean 30,000 meters? (= 30 kilometers)
    I think the distance is too far. As far as I know, Multy X is supported 3 units for maximum and can cover up to 7,500 square feet currently.
  • Rani
    No, I do not mean 30 kilometers.
    There's 20 meters.
  • Hanamichi
    edited December 2017
    I checked the specification, the coverage is 464 square meters.
    It should be able to meet your requirement (20 meters). But actual data transfer rates/coverage may vary from network conditions including: network traffics, building site material/construction/Multy X place, interference from other wireless devices and other adverse factors.
