NAS540 Shutdown
oxfrd
Hello together.
Is there any possibility to Shutdown The NAS by Smartphone/iOS by App? WOL by App is no Problem ..
thanks for your Support!
BR
#NAS_November
BR
#NAS_November
WOL is ok, because NAS can be waken up by magic packet through any WOL tool.But as I know, Zyxel APP ( zCloud and zyxel drive) doesn't have this feature, even Android...Most APPs were designed for data access, so I think official APP does not support, then no other APP else.0
You can shutdown the NAS by typing the command 'poweroff' in the command line (as root). So you can shutdown it by executing
ssh root@nas540 "poweroff"
from you computer. In this case it will ask for the rootpassword. If you install Tweaks and enable a non-volatile home directory for root, you can also install a keypair to do it login-less.0 -
You can access GUI from external web, and turn it off from your smartphone with this way, but it' secureless than ssh... Mijzelf solution is the best :-)0
You can do it with one button ssh on android.
Link it with the above mentioned command0 -
Hello guys
When I run "poweroff" from a ssh terminal, I get "Operation" not permitted. I do this as "admin".
Any ideas on how to get permission
regards Flemming0 -
You have to login as root. admin has not enough permissions.
That did it. Thanks.
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
