NAS540 Shutdown
oxfrd
oxfrd Posts: 1 image  Freshman Member
edited November 2017 in Personal Cloud Storage
Hello together.
Is there any possibility to Shutdown The NAS by Smartphone/iOS by App? WOL by App is no Problem ..
thanks for your Support!
BR
#NAS_November
  • Ijnrsi
    Ijnrsi Posts: 254 image  Master Member
    WOL is ok, because NAS can be waken up by magic packet through any WOL tool.
    But as I know, Zyxel APP ( zCloud and zyxel drive) doesn't have this feature, even Android...
    Most APPs were designed for data access, so I think official APP does not support, then no other APP else.
  • Mijzelf
    Mijzelf Posts: 3,047 image  Guru Member
    You can shutdown the NAS by typing the command 'poweroff' in the command line (as root). So you can shutdown it by executing
    ssh root@nas540 "poweroff"
    from you computer. In this case it will ask for the rootpassword. If you install Tweaks and enable a non-volatile home directory for root, you can also install a keypair to do it login-less.
  • Fredzoul1
    Fredzoul1 Posts: 97 image  Ally Member
    You can access GUI from external web, and turn it off from your smartphone with this way, but it' secureless than ssh... Mijzelf solution is the best :-)
  • Unomagan
    Unomagan Posts: 7 image  Freshman Member
    You can do it with one button ssh on android.
    Link it with the above mentioned command
  • FlemmingJ
    FlemmingJ Posts: 2 image  Freshman Member
    Hello guys
    When I run "poweroff" from a ssh terminal, I get "Operation" not permitted. I do this as "admin".
    Any ideas on how to get permission
    regards Flemming
  • Mijzelf
    You have to login as root. admin has not enough permissions.
  • FlemmingJ
    That did it. Thanks.
