Can this device expand the WiFi area between two different buildings?
Rani
I would like to get information about the multy x wifi system.Can this device expand the WiFi area between two different buildings?
#MultyX_November
#MultyX_November
You can check: SpecificationsA set of two Multy X units can cover up to 5,000 square feet.But it is wireless signal and interference from other networks/appliances/wall could be reduce the coverage. What is the distance between two buildings?0
About 30,000 meters between two buildings0
No, I do not mean 30 kilometers.There's 20 meters.0
I checked the specification, the coverage is 464 square meters.It should be able to meet your requirement (20 meters). But actual data transfer rates/coverage may vary from network conditions including: network traffics, building site material/construction/Multy X place, interference from other wireless devices and other adverse factors.0
Sign In to comment.
Howdy, Stranger!
