how I can to reset twonky server password on Zyxel NSA325 V2
bavbas
Hello, I forget twonky server password
This instruction is not working
https://www.qnap.com/en/how-to/faq/article/i-forgot-my-user-name-and-password-for-twonky-server-is-there-a-way-to-reset-them
error - cd: can't cd to /mnt/hda_root/twonkymedia
https://helpdesk.qnap.com/index.php?/Knowledgebase/Article/View/352/0/how-to-reset-the-password-of-twonkymedia-server-7x
this not working too........
#NAS_December
#NAS_December
Best Answers
You can find the config file at /i-data/md0/.media/twonkymedia as twonkyserver.ini
Try this file and remove your password.1 -
Through telnet/ssh, you can use following syntax to copy and move the file.But you should remeber to backup the original file to prevent if any un-expect situation.backup: cp #cp /i-data/md0/.media/twonkymedia/twonkyserver.ini /i-data/md0/.media/twonkymedia/twonkyserver2.ini#cp /i-data/md0/.media/twonkymedia/twonkyserver.ini /i-data/md0/xxxxxx
access the shared folder via CIFS/SMB and modify the file with note/notepad.....#cp /i-data/md0/xxxxxx/twonkyserver.ini /i-data/md0/.media/twonkymedia/and you may need to restart twonky service.1
how I can access this file?0
you mean modify?
if yes, you can open it with note/notepad/notepad++, some editor tool.
remember to backup the original file.0 -
can't find him from windows....... his is in linux file system in nas325
I can connect to NAS via telnet or ssh, but I don't know linux syntax0 -
access the shared folder via CIFS/SMB and modify the file with note/notepad.....#cp /i-data/md0/xxxxxx/twonkyserver.ini /i-data/md0/.media/twonkymedia/and you may need to restart twonky service.1 -
thank you,I will try this at home0
thanks all, problem resolved0
How did you resolve this having issues please........0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
