how I can to reset twonky server password on Zyxel NSA325 V2
bavbas
bavbas Posts: 5 image  Freshman Member
edited December 2017 in Personal Cloud Storage
Hello, I forget twonky server password :(
This instruction is not working
https://www.qnap.com/en/how-to/faq/article/i-forgot-my-user-name-and-password-for-twonky-server-is-there-a-way-to-reset-them
 error -   cd: can't cd to /mnt/hda_root/twonkymedia
Best Answers
  • Mihawk
    Mihawk Posts: 103 image  Ally Member
    You can find the config file at /i-data/md0/.media/twonkymedia as twonkyserver.ini
    Try this file and remove your password.
  • Mihawk
    Through telnet/ssh, you can use following syntax to copy and move the file.
    But you should remeber to backup the original file to prevent if any un-expect situation.
    backup: cp #cp  /i-data/md0/.media/twonkymedia/twonkyserver.ini /i-data/md0/.media/twonkymedia/twonkyserver2.ini
    #cp  /i-data/md0/.media/twonkymedia/twonkyserver.ini /i-data/md0/xxxxxx
    access the shared folder via CIFS/SMB and modify the file with note/notepad.....
    #cp /i-data/md0/xxxxxx/twonkyserver.ini /i-data/md0/.media/twonkymedia/
    and you may need to restart twonky service.
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    If you have ssh enabled on your NAS, you can use WinSCP to access the filesystem on the NAS.
  • Mihawk
  • bavbas
    how I can access this file?
  • Mihawk
    you mean modify?
    if yes, you can open it with note/notepad/notepad++, some editor tool.
    remember to backup the original file.
  • bavbas
     can't find him from windows....... his is in linux file system in nas325
    I can connect to NAS via telnet or ssh, but I don't know linux syntax
  • Mihawk
  • bavbas
    thank you,I will try this at home  :)
  • Mijzelf
  • bavbas
    thanks all, problem resolved  :)
  • Mendryz
    Mendryz Posts: 1 image  Freshman Member
    How did you resolve this having issues please........
