Access to USB HPv210w flash drive on Router Zyxel vmg8924-b10a
riggie
Hi Everyone,
Changed ISP and I now have the Zyxel vmg8924-b10a Router installed and working fine.
I have a flash drive in USB port 1 on the router, I can view the files on the drive on any Smart TV so that works fine. The problem I have is I have to unplug the Flash drive to load the files on to it as I cannot find out what the path is to make a shortcut so I can access it and load the files directly from my PC.
My last router displayed the share path but I have tried both paths shown in the picture but they don't work, I am not that sure what to do in this area so any help would be appreciated.
cheers
riggie
Tried these /mnt/usb1_1 /mnt/usb1_1/Movie & TV Series
#CPE_December
cheers
riggie
#CPE_December
Hi
I have sorted it, I Mapped the drive using the " Name " of the share in the " Share directory List " I called it " Movie & TV Series"
so the path is \\192.168.1.1\Movie & TV Series
I can now drag & drop files straight in .............. but as usual very slow transfer rate.
I noticed you use "File Sharing" to share videos.
Maybe you can try "Media Server" to share videos.
I didn't use "File Sharing", but I use "Media Server" and a 1000kbps data rate video could play smoothly on my PC with Media Player.0 -
Cheers SEJ, will give that a go soon. The reason I drop files into the USB drive is that when I switch off the PC, I can still access a few files on my TV downstairs, which makes it very handy.0
- 588 USG FLEX H Series
- 476 News and Release
