How do I set up two Zyxel Multy's?
Stockmens_2017
I can set up the first one but the second one doesn't connect? It keeps 'spinning' on my phone.
#MultyX_December
#MultyX_December
I found some official video for your reference.And you also can check some topic on FAQ.Below is my suggestion, hope it is helpful for you.1. Reset both Multy X.2. Follow the video to setup Multy X again.3. About add the 2nd node, please wait 3 minutes after you plug in power adapter, then LED will turn to blinking blue ready for adding.
If you're still encountered the problem, please share some screenshots, LED status, the model, O.S. version of your mobile device and Multy X app version.
Zyxel just released new APP for Multy X,
you can give it a try.
https://homeforum.zyxel.com/discussion/616/new-multy-x-app-1-4-0-is-releasing-now#latest
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
