SSL certificate by Let’s Encrypt and Zyxel NSA325 v2?
Jappo
Hello community,
I want to integrate a SSL certificate by Let’s Encrypt into my Zyxel NSA325 v2 to encrypt the data between the NAS and the web GUI which is accessible at https://some.dns.tld.
I got a folder called .well-known which I have to upload to the document root of the webserver running on the NAS to verify that I am the person that applied for the certificate. The folder has to be accessible at https://some.dns.tld/.well-known.
The NSA325 webserver’s document root is /usr/local/apache/htdocs if I am correct.
I can upload files via SCP with admin to /home/shares or with root to /root. Then I want to move them via SSH to /usr/local/apache/htdocs. But that throws an error:
I am pretty new to linux/server/ssh. So I hope you guys can help.
Thank you so much!
#NAS_December
mv: can't create '/usr/local/apache/htdocs/test.txt': Read-only file systemAlready tried this:
mount -o remount,rw /usr/local/apache/htdocsThat gives me this error:
mount: can't find /usr/local/apache/htdocs/ in /etc/fstab or /etc/mtabHow can I upload my folder to /htdocs?
Thank you so much!
#NAS_December
@Jappo
I think it is might not possible to change the folder as it is builded in firmware.
The way to use SSL certificate might only go SSL page and create self-sign certificate and provide to third-party certification authority do 2nd sign, then import it back to NSA325 v2.
- 441 Beta Program
- 293 Service & License
