zCloud app always need to reconnect
Snoodie
Posts: 5 Freshman Member
Hi, I'm having problem with my zCloud app which always need to reconnect to my NAS540 server.
is there any solution to fix this problem?
NAS540 firmware : V5.20(AATB.0)
zyxel cloud agent : 1.0.5zypkg0105
zCloud Apps version : 2.2.6
#NAS_December
#NAS_December
You NAS540 is using old firmware, and the newest now is v.5.21(AATB.0)C0.
For your problem, do you mean that you can save account and password on your zcloud, but everytime you use zCloud, then you have to type account and password again?
Or do you mean "Zyxel Drive"?0 -
Hi, thanks for your quick respond,
Sometimes i don't dare to update to the latest version, because i ever encountered the problem, so i stay where it stable.
For my problem is the drive folder, whenever the problem occur, only photo folder is showing. I need to remove the domain and login again to be able see the rest of the drive folder.0 -
That is weird, so you use domain not IP address? If yes, that how about use IP address on your zCloud APP?
Have you tried to reinstall the APP?0 -
Yea, im using myzyxelcloud domain, never try direct IP so far, will give it a try.
Already tried reinstall apps same problem occur, and my office around 20 user using it with same problem.0 -
Already tried direct IP same thing happened0
I did the test, but didn't see the problem...
Maybe you can try on the LAN side, if the problem is still there, then try firmware upgrade or reset..., but if the problem doesn't occur, and only through WAN access, might something wrong with router, because you had tried IP address, but still got the same problem, then it is not related to cloud server.
Ok, will try with the LAN side 1st then try upgrade firmware. Thanks again for your respond.0
I have the same problem, when i want to acces my files injeed to logout and the login again
nas520 if you have any clue how to solve this tell me
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
