How to edit the WAN settings? Secondary DNS?
Cappucco
I did set up the system with a Static IP. On setup there was no possibilty to enter the secondary DNS. I don´t find any possibility to edit the WAN and LAN settings.
Any solution?
THX
Juergen
#MultyX_January
Any solution?
THX
Juergen
#MultyX_January
About you mentioned:- WAN Static IP has only one DNS can be configure.- You need to reset and reconfigure Multy X if you want to change WAN status.
- LAN (DHCP pool) cannot edit.These are current design of Multy X. So, I have moved this post to Ideas Discussions.Thanks for your feature request and we will evaluate it.
- 3K Nebula
- 222 Nebula Ideas
- 618 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
