Auto negotiation 10 vs 100 vs 1000
Rob
I am using a GS1100-16 in my home and have noticed that a speed test on any connection in the house only delivers 10Mbs. Reading around the topic of auto-negotiation across the ports suggests that each is being throttled to that figure, rather than 100 or 1000. Is that correct? How can this be altered? I have a 300Mbps connection into my home but it seems that no single point in the house can use it to its full speed.
Can I determine how the speed of each port is managed?
#Biz_Switch_January
#Biz_Switch_January
Ignore this. After several different tests it appears to simply be broken and will need replacing. Annoyingly just outside its warranty :-/0
try to replace your ethernet cables with CAT6 ones.
10Mbit connections established when cable or pins are damaged or not even connected!
with a normally working cat5 or cat5e (which is the most common ones) under 100m length you will get 100mbit.
*I apologize in case you already know that stuff, just trying to help..
also check if your modem-router device support up to 1gb ethernet.
if not you will not be able to reach 300Mbit with a simple setup.
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
