[Errno 28] No space left on device
jbn
I'm getting
error messages when trying to copy to my ZyXel NAS540. To me, it looks like there is space available,
#NAS_January
[Errno 28] No space left on device<br>
~ $ df Filesystem 1K-blocks Used Available Use% Mounted on ubi7:ubi_rootfs2 92892 51160 36952 58% /firmware/mnt/nand /dev/md0 1966352 192368 1674096 10% /firmware/mnt/sysdisk /dev/loop0 151719 135159 16560 89% /ram_bin /dev/loop0 151719 135159 16560 89% /usr /dev/loop0 151719 135159 16560 89% /lib/security /dev/loop0 151719 135159 16560 89% /lib/modules /dev/loop0 151719 135159 16560 89% /lib/locale /dev/ram0 5120 4 5116 0% /tmp/tmpfs /dev/ram0 5120 4 5116 0% /usr/local/etc ubi3:ubi_config 2408 96 2156 4% /etc/zyxel /dev/md2 11616404496 5495211768 6121192728 47% /i-data/ad82b6f7 /dev/md2 11616404496 5495211768 6121192728 47% /usr/local/apache/htdocs/desktop,/pkgand inodes available,
~ $ df -i Filesystem Inodes Used Available Use% Mounted on ubi7:ubi_rootfs2 0 0 0 0% /firmware/mnt/nand /dev/md0 124928 12 124916 0% /firmware/mnt/sysdisk /dev/loop0 39200 6983 32217 18% /ram_bin /dev/loop0 39200 6983 32217 18% /usr /dev/loop0 39200 6983 32217 18% /lib/security /dev/loop0 39200 6983 32217 18% /lib/modules /dev/loop0 39200 6983 32217 18% /lib/locale /dev/ram0 126455 8 126447 0% /tmp/tmpfs /dev/ram0 126455 8 126447 0% /usr/local/etc ubi3:ubi_config 0 0 0 0% /etc/zyxel /dev/md2 365895680 521745 365373935 0% /i-data/ad82b6f7 /dev/md2 365895680 521745 365373935 0% /usr/local/apache/htdocs/desktop,/pkgI suspect it's an i-node problem. I have a folder with several hundred folders with 1000 files in each of them. But, I can't figure out what's wrong and I've never done any RAID admin.
#NAS_January
Could it be a user quota problem?I've never done any RAID admin.The raid array is a blockdevice like every other. The filesystem doesn't 'know' it's on a raid array. Error 28 is a filesystem error, and so it has nothing to do with raid.
How are you accessing the volume?0 -
Thanks for your time, Mijzelf!
I'm accessing via SAMBA, mounted as an OSX volume. I've replicated the problem via a python script (package pysmb) using different user credentials. Both users have unlimited quotas according to the ZyXEL web user interface.The curious thing : the problem seems to be localized to one sub-tree. I just successfully transferred 500mb to a folder on the same share without problem. Afterwards, I tried to copy the exact same file that just successfully transfered to the failing subfolder -- failed immediately with ERRNO 28.0 -
Does that folder name/path contain any strange character?
That error 28 is a [i]local[/i] error on your client. So for some reason the samba client on your Mac spawns this error. Of course it [i]can[/i] be a pass from the server.0 -
No, it does not. In fact, every character in the misbehaving subtree is in [ABCDEF0123456789], as the file names are hashes of the contents.
That local error exists on both the OSX SAMBA client and the python package one. Any advice on how to experiment with that share via SSH on the NAS? You pointed out it's just like any block device, but I'm oh-so-nervous to manipulate it directly since it's may backup and I don't have room to transfer it to another device while experimenting...
(Thanks for continuing to try helping me. I'm at a loss. It seems like an odd problem.)0 -
Any advice on how to experiment with that share via SSH on the NAS?You can try to copy that file from the other subtree to the misbehaving subtree, to see if that rises an error.
The subtree can be found in /i-data/ad82b6f7/<sharename>
If that also fails, have a look in the kernel log buffer, using dmesg.
If that doesn't fail it should be nice to have a look at the samba logs, but unfortunately they are disabled on the NAS.I'm oh-so-nervous to manipulate it directly since it's may backupYou are aware that it's not a backup if it's the only copy you have? A backup implies that you have another copy of the data. You should have if the data is valuable. Your NAS will fail some day. Just like any storage medium.
- 441 Beta Program
- 294 Service & License
- 461 News and Release
